Old 06-12-2021, 04:02 PM   #11
ecp
did you have plastic bits in the oil pan?
Leak down test would have helped before as that will show a valve issue usually.
snap some pictures of the head, maybe it will be obvious if it's a spring.
You did lock the cams right? Both of them?
Yes the dealership did a leak down test and borescope. I’ll try and attach photos if i can figure it out, i have an iphone. and yes i have both cams locked
There’s always been some plastic bits in the oil. I’m pretty sure it’s the chain guides. i replaced the IMS last july
ecp is offline   Reply With Quote
