Old 06-12-2021, 12:32 PM   #1
Beelzy
Beelzy's Avatar
What is this part! It leaks coolant like a sieve! (2004 base)
So my 2004 started leaking coolant like a running garden hose.
I checked the obvious, water pump and coolant tank only to have to remove the rear wheel to
see this valve of sorts leaking. It's the one attached to the hose with the green tape.
What is it and what part number so I can source a replacement?
Any help would be greatly appreciated. Many Thanks!
I believe it to be this part #12 on this diagram I borrowed. Oil cooler valve?
Beelzy is offline   Reply With Quote
