Old 06-11-2021, 09:08 PM   #13
Didier
Originally Posted by CrisZenithBlue View Post
Only thing I can think if is you have to somehow get those transmissions to spin forward to fully closed position to get the light to go off and windows to go fully up. Maybe spinning them manually somehow if the motor doesn't work at all or isn't connected?
Motor works and i can use it on the buttons. I have already drive motor both direction and try stop all possible places, but light stay ON. Do you know what is the fully up position on the motor? Both transmissions have markings (small lines). One sign is in the rotating part and the other is on the outer ring, I have driven the marks in alignment, but still the light is on.
What really turns that light on? Some microswitch probably but what? And whether the microswitch should be pressed or open. I have already connected the wires of the B pillar microswitch.
Didier is offline   Reply With Quote
