Old 06-11-2021, 03:00 AM   #10
Didier
Originally Posted by CrisZenithBlue View Post
Most likely the top doesn't open or close all the way, the left and right transmissions could be out of synch or maybe one of the nylon gears inside of them is broken and it doesn't pull the top down tight enough so the microswitch thinks top is not fully down.
I would open both top transmission and check the condition of the gears inside and then readjust/realight/synch the top so it opens closes the same on both sides.
Theres an article on pelican site explaining the process
OK, must open and check those transmissions. They seems to be sync.
Can I bypass the entire gearboxes microswitch by connecting the wires from the gearbox connectors? Or somewhere else? Gearboxes are completely useless when the top is manually operated.
Didier is offline   Reply With Quote
