Originally Posted by elgyqc
When I replaced the AOS the hose between the top of the AOS and the intake manifold was so stiff I could not reattach it. What I ended up doing was to cut the tubing from the 2 end connectors (including removing the ends of the tubing where they are fitted over the connectors)...
... and joining the the original tube to the connectors with pieces of 3/4" silicon heater hose.
I will have to wait to see if the fit is snug enough without a sealant.
This should also work for repairing the long hose from the AOS to the front left of the engine.
Why did you keep the accordion hose part and not just use silicone hose for the whole thing?
