Old 06-05-2021, 04:50 PM   #13
Gilles
[QUOTE=steved0x;576463]My front on one side wobbled until I added the torquing force of the axle nut. Otherwise the two inner races can slightly spread and allow a slight wobble. You might be able to test it using the bearing press to clamp the inner races together and verify the wobble is gone. The 340# of torque really clamps the inner races together. Or it might be in crooked... QUOTE]
+ 1
After you torque the wheel nut the wobble should be gone, it is important to torque the big nut 'before' you move the car
Gilles is offline   Reply With Quote
