Same issue here on both rear hubs
I have this identical problem after replacing both rear wheel bearings. Could it be a batching problem with the bearings. ?
Mine are stamped FAG from Slovakia.
The comments about the 2 inner races not being pressed together and being the source of wobble makes sense though. I tried pressing with the bearing puller and the wobble has gone. Hmm a bit un-nerving though.
Patssle are your bearings stamped FAG brand from Slovakia. ?
