Old 06-05-2021, 08:04 AM   #11
blue62
Originally Posted by Rundtinden View Post
Changed the rubber boot between the plenum and the intake. Checked for leaks. Then took it for a test drive. Cel came on again after 80km. Car pulls strong, but seems to have a problem on low throttle settings. New codes: P300, 301, 304, 305 and 306.
Changed plugs and inspected coils. Could this be a fuel problem?
Filter perhaps?
P300 is a general misfire code.
P301 is cyl 1 bank 1.
P304-305-306 ia all cyl.on bank 2.
So You have an issue that is causing misfires on both banks.
Could be a vacuum leak.
Could be a fuel problem.
could be an electrical problem.
Could be a sensor problem like the MAF sensor.
Could be any number of things.
Best thing to do is go with a good automotive diagnostic procedure.
That is: start with the simplest things first and work your way up step by step.??
I assume you have done the basics??
Checked battery condition via a load test?
Looked at plugs and coils??
Has good clean fuel???
Good clean air filter??
After that:
Start with a proper vacuum test with a vacuum gauge.
If you know how to use a vacuum gauge for testing you not only can test for vacuum leaks but it will give you a good baseline for overall engine condition.
Greater engine loads and more throttle create greater fuel demand.
You say it pulls strong: does not sound like a fuel issue to me although it is possible. It doesn't sound likely.
If you have something like a Durametric scan tool you could hook it up and look at fuel trims and O2 sensor response to try to determine if you have a lean or rich fueling condition. If you do this could help in knowing what to look for as the issue.
From the info you have provided my guess is you have an air intake issue:
Vacuum leak
Maf sensor issue
IAC issue
EVAP system leak
Something related to air intake
You stated you had air leaks in the intake. you did some work there.
Do a vacuum test with a vacuum gauge it will help tell you if you have fixed all the vacuum leaks.
Or it could be electrical
Lets try to find the cause of the issue.
Give me more info on the car.
Miles?
Is it all stock or are there mods?
If so what mods?
Stock air filter?
So if you start if and let it warm up how does it idle??
What RPM does it idle at?
Smooth with no issue? or lumpy- rough?
Hunting= RPM moving up and down?
If it idles lumpy or rough or hunts, will it smooth out if you hold the RPM at around 2000-2500 RPM?? Do this in neutral and let me know.
Pull the freeze frame data with your code reader and post it.
That will tell me the conditions when the codes were set.
