Old 06-04-2021, 05:25 PM   #10
ecp
So just spit balling here.
I would expect the plugs to be wet because of the Sea foam.
I would expect them to smell a little like fuel because the fuel/air mixture was not burning due to no compression.
Smelled a little oily hmmm and looked a little like carbon.!!!!
I would expect a little carbon if those Cylinders were getting a little oil in the fuel/air mixture when the engine was running.
carbon=burned oil.
Was your exhaust ever blueish or whitish or not looking right???
Only when the aos failed. And then the replacement failed two months later. Nothing visual out of the exhaust, and i would have seen it because it’s a “race” exhaust.
There’s always a film of oil in the intake from the AOS. it wasn’t like that when i bought the car (it was bone dry inside), but i could never quite figure out why it never went back to having zero visual oil in the intake after replacement. maybe just an inferior part to the original i suppose, but good enough to pass.
ecp is offline   Reply With Quote
