Old 06-03-2021, 05:59 PM   #15
ike84
Originally Posted by porschefan76 View Post
Hey Ike! Yea, I have the Katalog as well and it doesn't go much into it. So far as I have gathered, it can (mis)function like a relief valve. I pulled the old one off of my original tank because it was working fine. It truly just bolts to the top of the reservoir with a small passage that allows it to act like "the highest point of the cooling system" similar to an old radiator cap so you can burp the system properly. However, the gaskets have been known to fail and there were a couple of threads (I cannot find them right now) that showed the valve allowing coolant out onto the top of the tank and that coolant would make it's exit out of the overflow tube. Here's a pic of my old one:
that black plug in the center is rubber and the spring force holds it closed until you use the metal tab on top to open it to evacuate air. Best I can tell from what I've heard, the rubber on the center plug gets tired or, as mentioned earlier, the rubber gasket can fail. The rubber gasket isn't shown in the pic because I disposed of it, expecting to order a new one if I ever needed to swap this valve in.
Let me know if you need more pics. I disposed of the old tank or I'd have taken a picture of the port where the expansion valve connects to the tank as well. Good luck!
Sorry fan, I think I misworded my question (although I appreciate the knowledge on the burp valve too! My new one is coming in the mail so the more I understand about it up front the easier that job will be). You mention the gaskets - are you referring to the two o rings that sit between the valve housing and the tank?
My main intrigue is actually the overflow tube (not valve) which is the open ended tube that comes off the tank (if I remember correctly it's the lowest hose coming off the manifold) and opens to atmosphere. If the system is pressurized then how does this tube not just constantly do gas and coolant? You may have alluded to it acting as a drain for the top of the resivoir tank... Does that mean that it's only purpose is to dump coolant that comes out the burp valve or around the tank cap?
Thanks again for the time (and effort! Love the pics) in helping me!
Sent from my POCOPHONE F1 using Tapatalk
