Old 06-03-2021, 04:40 PM   #11
boxxster
I decided to stick with Ben's. Though to be fair, I had the 997 shifter in my car for 5 years and was perfectly happy with it. I think you'd be happy with either over the stock shifter. Depends on what you can find a deal on and how inclined you are to modify a stock shifter to use Ben's. As Kevin pointed out, if you go the 997 route you can sell your stock one to offset the cost, which is what I did when I originally purchased mine.
I ended up getting a deal on Ben's shifter already installed into a factory cradle from a generous forum member here, so for me it was an easy swap. It's definitely shorter and tighter feeling than the 997 unit. But like I said, both are a nice upgrade from stock, especially if your current shifter has some miles on it.
