Old 06-03-2021, 10:48 AM   #11
blue62
Originally Posted by ike84 View Post
Blue, when I ran the OEM TStat my temps were cosntantly in the 190ish range. Never past the 0 but they are definitely lower now than what they were. Mind you that was also under a very different driving circumstance - then I was in a big city, deep south so hot as balls always, with very little room to run. Now I'm in a cooler climate and air is usually running through my radiators at 90-110 mph when I am running systems tests
Yesterday I ran twice with the burp valve open and no overflow. Definitely steam coming from the top of the tank though, hard to say exactly from where. Slightly sweet smell in the cabin with the top up (toward end of the drive). Fun note - over 60 mph we can drive in the rain with our tops down! Thanks science!
This morning I ran it with the burp valve closed and again no overflow. Slightly sweet smell coming from top of tank but no steam. Same smell from passenger rear wheel well but no overt fluid loss or steam.
Despite losing what looked like at least a liter of coolant two days ago on my driveway, the coolant reservoir is still completely full.
No funny looking or smelling exhaust under any circumstances since I have put high flow cats on.
I recently drained and flushed the system, and did oil change. No evidence of intermix on either side. With that being said, some years of subaru h-6 (i forget which generation) have head gasket failures and they dont usually see intermixing.
New burp valve is on the way so that will be getting swapped out for good measure. Pressure tester is on its way and I will post results.
Maybe all I have done is overfilled the coolant reservoir (although I'm not sure how I would have been able to physically do that) and the dump tube was just doing its job. If that's the case I will be thankful for the mistake.
That is why I asked if you had allowed it to find a settle out point.
The issue could be as simple as the coolant needing expansion room.
Or the burp valve could be faulty.
A system pressure test should tell all.
The Idea that if you don't have intermix of some kind then you don't have a bad head gasket does not prove out in my experience.
What I have seen mostly with a bad head gasket is either a whiteish (steam) exhaust or the overfill tank acting as if there is air in the system. Or both.
You get air being pushed back into the coolant system by the piston. So the overflow tank gurgles and air pressure pushes coolant out.
Sounds like you have a great driving area.
I have The Columbia River Gorge and lots of back roads in the Gorge area.
Canyons, Mountains, flats.
On the back roads I see very few other cars. So I can play or just cruise
Let me know what you find with the pressure test.
I am always interested in results and outcomes.
