Side section (suspension cross member sub frame question)
Has anyone had an accident and broke one of these. I'm curious if the frame gets damaged and after changing the subframe if all the mounting holes lined back up.
What broke on my car is the hub carrier, this sub frame, control arms, drive shaft boot. ( I think the driveshaft isn't bent but and angle the outer CV had when then rim folded a bearing popped out so going to replace the drive shaft.
Just curious if anyone has had an issue changing one of these subframes.
I was going to buy a used one and hoping it lines up. Also, I don't think anything from where the front transmission bolts onto the subframe bent. And the rear looks fine.
Thank You
