Old 06-02-2021, 09:09 AM   #16
blue62
Originally Posted by Johnny5 View Post
No worries it’s a place to discuss anything exhaust bolts or studs! ��
If I was to go bolts I would probably go factory. But I’m interested in studs for my new SS headers. I found a few SS studs and read put loctite red or blue on the cylinder thread and copper anti seize with copper nuts. I’m just afraid of messing up the cylinder head from corrosion (read about it somewhere) or them snapping in the cylinder and having a hard time drilling them out.
When installing one type of metal into a dissimilar metal. like mild steel into Aluminum.
Your going to get Galvanic corrosion. It is caused by an electrical process. The dissimilar metals actually create an electrical charge. Even if you use stainless steel.
So because the Engine block is Aluminum I use Anti-seize on things like spark-plugs, or exhausts studs- or bolts if I have to replace them.
If I have to replace an exhaust stud or bolt I use mild steel with Anti-seize. That way if I ever have to go back in and I break a stud off it is easy to drill out.
The practice of using mild steel exhaust studs with brass or copper nuts has been used in the Automotive industry for over 100 years.
They did it that way so that the nut would not seize to the stud from the affects of repeated heat and cold cycles.
The reason you see bolts now being used to hold the exhaust manifold on is because it is cheaper.
Profit is the driver. A bolt is one piece and one step. As opposed to two pieces and manufacturing processes. And two steps to install.
Use what suits your needs or what you feel is best for the situation.
Some may say I am over thinking it, I am just using what has worked for over 100 years for that specific application.
