Old 06-02-2021, 05:09 AM   #3
Spinokovits
There's a fuse on row B or C that will keep the vehicle from starting if it's blown. Same with the fuse on the immobilizer and if you have a bad starter relay located in the trunk. I believe only north america has to press in the clutch to start. Everywhere else has the ROW tune and you can start without your foot on the clutch
Hmmmm I've checked all the fuses, but I will do it again just to be sure that I've nothing overlooked. ;-)
The starter relay is not bad.
If it is supplied with power when it is removed, it switches as normal as it should.
The problem is apparently that it is not activated by the engine control unit.
The question is why?
I only bridged it on a trial basis to rule out the starter motor as faulty.
I think the reason why the starter relay is not activated by the ECU is the same why there came no signal to the injectors and spark stages.
b.r. Spinokovits
Spinokovits is offline   Reply With Quote
