Old 06-01-2021, 07:07 PM   #29
ike84
Originally Posted by Robert986 View Post
Ok, the car is back from the Tuner!
The bad part: It seems my emergency brake on one side has collapsed somehow, there is an evil scraping sound inside it, so I can not (should not) drive the car.
The good part: When the emergency brake for a short while stopped making those noices I took it out for a proper spin, and man it runs really really well. You know the old tale "Porsche cut the nuts of the Boxster not to compete with the 911" Well, the nuts are back, and this time itīs personal..
Seriously, it does pull stronger than before and the sound is glorious.. Dark low tone when cruising and angry GT3-ish when stepping on it at high revs. And there is no drone.
Tomorrow I will take a look at the emergency brake, or rather whatīs left of it. Then hopefully I can finally get this season started. :dance:
Robert, I am curious. Did your tuner share with you exactly what he did and how he did it? How did he measure performance gains (dyno, street runs)? How did he dial in adjustments? What are your knock sensors (if still enabled) telling you about the setup? Do you have any EGT measurements? Any AFR measurements?
Curious minds want to know!
Also, did you wind up going with the colder dial plugs? (I think that was you who mentioned that, right??
Sent from my POCOPHONE F1 using Tapatalk
