Old 06-01-2021, 10:33 AM   #1
Harvey Mushman
2001 Boxster S for sale in Central Florida
2001 Porsche Boxster S $14,000
Health requires sale, new over $60,000, Florida car, always garaged
Full history and receipts since new, owners manual, 123,000 miles, PPI available
Full leather, all black, excellent leather with memory seats and dash, new top with glass window/ gears/ cables, included OMP rally seats/ mounts/ 5 way Simpson harnesses, cruise control, Litronic clear coated headlights, LED taillights
Console and interior professionally painted- no soft touch paint
Engine
no oil leaks, LN IMS replaced at 105k, RMS, clutch, AOS/ bellows, water pump pierburg, MAF, all engine mounts, DT-40 oil + Blackstone, LN filter adaptor, magnetic drain plug, Porsche air filter, 160*thermostat, Porsche coolant, oil cooler o rings, new starter, spark plug tubes, plugs, new belt idlers, Fabspeed headers/mid pipes, secondary air delete(included), AOS capture can, FVD deepsump with baffles, FVD ecu flash, ERP underdrive pulley, Variocam slides, solenoids/ actuators, oil pressure relief valve/spring, IPD plenum+ 997 throttle body, Porsche fuel filter/ gas cap, pentosin PS fluid changed/ PS cooler included, replaced ignition switch, ball bearing short shifter, waterproof immobilizer box, radiator fans/ thermostats, grill screens, Porsche brand coolant tank, 4 F/R trunk shocks, Odyssey 925 battery/mount, Sony XAV-AX 1000 double din+ backup camera+ Appleplay, cold a/c /flapper valves, Porsche floor mats, engine carpets/rear storage/speakers, F/R trunk carpets/liners
Transmission
no oil leaks, OEM Delvac 75w90 changed Clutch and RMS/ safety wired cables
2 new OEM Boxster S axles, CV boots
Suspension
Koni 2 way adjustable, Eibach 500/550 springs, adjustable aluminum camberplates, recent alignment, front and rear trailing arms, Carrera Light 8/10 wheels trued, balanced, painted, Powerflex bushings, Michelin Pilot Supersport 245/275, Tarret swaybars F/R +drop links, 987 club sport rear bar fitted, calipers rebuilt/painted/Hawk pads(2sets), SS brake lines, GT3 brake air ducts, Pedro subframe brace, Boxster lift bars
Covercraft sun cover + sun shield tonneau
Harvey Mushman is offline   Reply With Quote
