Old 06-01-2021, 10:29 AM   #1
Spinokovits
Boxter Newbe with massive problems....
Hi guys,
I've bought a Boxter 986 from 1998 (really cheap) which didn't start.
Because I'm technican (electronic and mechanic) I had no concerns about not getting the problem under control
But now after more than 50 hours of unsuccessful troubleshooting, I've got a little nervous.
Here the wohle story:
The previous owner of the vehicle parked it in winter 2014 (Garage).
In the spring of 2015 the engine did not start.
The car came to a free workshop for checking and changing the battery
For reasons that are no longer comprehensible, the vehicle has been parked there outdoors, not overcahted, for almost half a year.
During this time, the rear window apparently cracked and water penetrated into the interior of the vehicle.
Inevitably, this destroyed the control unit for alarm, convenience and immobilizer, under the driver's seat.
This control unit was renewed by a Porsche workshop and adapted to the vehicle key.
Nevertheless the engine still did not start.
Porsche workshop says engine ECU must be defective.
For this (new) ECU, Porsche wants to see €6.000,- on there bank account.
In words: SIXTHOUSEND, no joke.
Since 2015 the engine has not been running.
In this 5 years the car was in several free workshops, but no one could solve the problem.
Therefore the previous owner decided to sell the vehicle, and that's how I came to this game.
I bought a used ECU at local car reclaimer for €500,- and cloned the immobilizer data from the original ECU to the spare ECU.
But the symptome is still the same.
When turning key, ignition is on, all lights in dashboard are lit, but no reaction (and no noise) of the startermotor.
The starter itself is 100% ok, because when I bridge the "startenable-relay" in trunk, starter runs but engine still doesn't start.
What I've found out:
"Main-relay" is correctly activated by the engine control unit.
5V Output Voltage of the ECU (for some sensors) is present.
"Startenable-relay" is not activated by the engine control unit
I've checked all fuses, all relevant cable connections (I have original circuit diagrams) but no abnormalities.
Faultmemory of Motor-ECU and Alarm-Immobilzer-ECU says 0 Errors !!!
All supplyvoltages (30, 15, 86s and 31) on both involved ECU's is checked and seems to be good.
Signal of "engine-speed-sensor" and "hall-sensor" is checked (with scope) and is present in plausible amplitude and frequency too.
But there is no measurable signal from the ECU to the ignition stages AND injectors.
I'm really confused now.
To me it seems as if the engine control unit is missing any "start release"
So I have a question to you 986 owners:
Is there any status which can prevent engine start ?
With status I mean position of the convertible top, engine cover, trunk lid, driver/passenger doors, and so on.
It's all open because of troubleshooting.
Is it necessary to press brake and/or clutch while starting ?
Or does anyone have hint for me where to search for the problem ?
b.r.
Spinokovits
Spinokovits is offline   Reply With Quote
