Old 06-01-2021, 12:08 AM   #11
Johnny5
Originally Posted by ike84 View Post
As blue said, go with copper nuts (not stainless). The reason for this is that same composition metals will undergo "cold welding" under high temperature and pressure, whereas dissimilar metals (i.e. steel and copper) will not.
It's a neat process. It happens in a total vacuum. Touch two steel rods together and they become one. Here, the heat and pressure just serve to drive it all the oxygen molecules out from between the iron molecules.
Knowledge is power!
Btw, the downside of using threaded rod instead of actual studs is that the studs have a hex head cut into the end, whereas the rods will require double nuts to torque and loosen.
I used m8 x 50 mm studs for a Ford V8, cost $15 for the dry on Amazon.
Sent from my POCOPHONE F1 using Tapatalk
Thank you for the response and additional info. So you happen to have a link to the set you bought with the hex at the end?
Johnny5 is offline   Reply With Quote
