Old 05-30-2021, 01:37 PM   #16
ecp
If bank 2 O2 Sensor gave no signal in bank 2 but it did when you switched it to bank 1 then the sensor works.
So you have a wiring problem on bank 2 O2 sensor wiring.
Sounds like you have multiple issues.
What cylinder are you saying is dead.??? And why do you think it is dead????
Did you get a code for the bank 2 O2 sensor not working???
I have aftermarket headers, and the o2 attaches onto the pipe coming off cylinder 6. i have no o2 codes. I think the cylinder is dead because there is no signal coming off that sensor even after i’ve verified it works. so if there is no combustion happening it would read close to .0v like it is? I pulled cam plugs and verified that the can timing isn’t out since everything lined up with my locking tools from the ims kit.
I’m going to try and see if it is a wiring issue with the o2 circuit, but i dont see how it would just fail out of the blue, but anything is possible i guess. I tried attaching a link to a video i posted on youtube showing how the car sounds and runs but i don’t think it let me post it
ecp is offline   Reply With Quote
