Old 05-29-2021, 11:01 AM   #5
bg305
01 Seal Gray 986 S
bg305's Avatar
you can get the slx5000 for around $1100 shipped.
I can attest though you can remove the engine out of a 996 & 986 with the quickjack
Now, when a quickjack comes out with about 6" more lift...that will be a big thing
You make great points, especially given the low "logistics" plug and play aspect of the quickjack. I do have a question though on the height the slx5000 says max height (with truck adapters) is 23.75".. It is my understanding I need 26" (I think with the bumper off but maybe that is the difference).. How do you set it up to get engine out? Do you do engine / trans together or separate? (and would that make a difference or are both possible?).
Many people do mods on the mid rise to cut out the rear bar and make it removable. Doesn't impact the integrity of the lift
This is interesting to me, the style that I am most interested in from my research at the moment is the open center ones but I think these are the most likely to be a problem for the engine because they do not have the arms that extend to the lift points as the traditional scissor styles do like the atlas I linked.. I am going to keep reading
Now, if you have the height for a 2 post, it is still the best route to go. If concrete is a concern you could just cut out some of it for just the posts. Even if you have someone do it for you, shouldn't cost more then $500 I bet to do it right. Of course with a 2 post, it's also best to have someone do the install for you. You could also do the same for a maxjax but by the time you buy it, lift truck, concrete you would be looking at $3k.
Good points here as well, 3k is not outside what I am willing to pay to get it done so that I can use it for next 10, 20 years or more (hopefully). The space still is tight though the side of the 2 car I want to put it on barely has any space on the door side and the other post that I would remove is between the cars and even though I can remove that one, I see having the car up for long time in my future as I take apart the engine. Also storage is an issue when the other post is out.
Thank you for all the feedback, it has been very helpful.
bg305 is offline   Reply With Quote
