Old 05-28-2021, 05:22 PM   #7
97gtaboxter
Originally Posted by PLP View Post
OK, so 911monty confirmed what I suspected.
see this vidieo.
https://www.youtube.com/watch?v=zeQfR5Q2KlQ
To remove the headlight - it just comes out, but this one, equipped with Litronics, has an additional plug that is used to adjust the headlights.
Many HID systems had autoleveling - if the car is empty, the lights will light up the road fine, if the car gets heavy, front may lift up and then they light up too high. Hence, autoleveling will adjust them down.
Can be done manually or, if you never drive with extra load (actually, quite hard to do in Boxster) - never touch it again.
Ok so the only thing that won’t work is the auto level feature. How do you manually adjust?
97gtaboxter is offline   Reply With Quote
