Old 05-28-2021, 01:53 PM   #2
97gtaboxter
Ok thanks PLP. So basically because my car was originally fitted with the Xenon assembly I won’t have that extra connector?
What about the washer at the corner? Would that be an issue?
Forgive me for my ignorance. I am new to this world.
I may have been able to source a pair of Xenon headlight assemblies for a reasonable price so this is why I am asking. I don’t want to purchase it and then it doesn’t work. As long as it works I am ok with that.
Originally Posted by PLP View Post
OK, so 911monty confirmed what I suspected.
see this vidieo.
https://www.youtube.com/watch?v=zeQfR5Q2KlQ
To remove the headlight - it just comes out, but this one, equipped with Litronics, has an additional plug that is used to adjust the headlights.
Many HID systems had autoleveling - if the car is empty, the lights will light up the road fine, if the car gets heavy, front may lift up and then they light up too high. Hence, autoleveling will adjust them down.
Can be done manually or, if you never drive with extra load (actually, quite hard to do in Boxster) - never touch it again.
97gtaboxter is offline   Reply With Quote
