Old 05-26-2021, 07:29 AM   #11
ike84
Originally Posted by Kroggers View Post
Installing an aftermarket AFR guage is a good idea. Can I install this in the bung I have for the post-cat o2 sensors, as I do not need these. Or do I need to install the AFR before the cat?
The best position for a wideband sensor is in the header collector. Post cat exhaust is leaner than the gases in the header/collector. How much leaner depends on a lot of things. I know some guys will temporarily clip an afr sensor in the end of the tailpipe for reads while tuning. I don't have any direct experience with this technique by you may want to just try it and see how your reads look. If they look off, then I would install it precat if possible.
Sent from my POCOPHONE F1 using Tapatalk
