Old 05-23-2021, 07:01 PM   #2
blue62
Originally Posted by Aanic View Post
Ok team
I just put in a used engine into my 99. I have some weird idling issues. On initial startup the engine revved straight to 4k, then slowly backed down as it warmed up. Warm its fluctuating between 1 and 2k.
I cleaned the ICV, then replaced it with another one I have. Same issue. I unplugged the maf and idle stayed steady but I doubt its a maf issue. I've got one of the ICVs soaking with some maf cleaner and will try swapping it it again tomorrow.
On the plus side, it moved for the first time under its own power in 3 years so that's hip.
Aaron
When you unplugged the MAF and the idle stayed steady what RPM did it steady out at???
blue62 is offline   Reply With Quote
