Old 05-22-2021, 11:17 AM   #1
Boxstard
Your AC shouldn't cycle on/off. If worried I would hook up a set of gauges to check the high & low side.
With that said the 944's I owned would cycle it on & off. With the 986's I have had though it wouldn't cycle like this.
If it is designed not to cycle on and off, temp is only modulated by blending warm air from heater core? It seems inefficient to keep the compressor loaded all the time, even after it gets cold enough to blend warm air, when it can get shut down.
