Thread: Car Overheating
Old 05-21-2021, 08:05 AM   #11
xX2pro4uXx20
In your other post you also reported a P0117 code for temp. sensor malfunction.
Do you still get that code?
Coolant coming out of both the overflow and the cap.
Caused by overheated expanding coolant?
Bad head gasket,rare on these cars.
Air trapped in the system.
bad thermostat.
bad water pump.
Starting to sound like you have an issue with the water pump not working.
The last time I checked the code was gone. The only code I have now is a code for manufacturer control whatever that means. And yeah I was thinking that it could also be the water pump whenever I searched up some stuff about these issues. Should I also replace the thermostat while I'm at it?
xX2pro4uXx20 is offline   Reply With Quote
