Thread: Car Overheating
Old 05-21-2021, 07:40 AM   #10
blue62
Originally Posted by xX2pro4uXx20 View Post
Yeah it looks like before I was loosing coolant out of the cap since it was coming from the overflow tube. So my guess is the cap wasn't sealing. I can not see any gel anywhere, I'm just guessing in that one since it only started happening whenever I added coolant to it.
In your other post you also reported a P0117 code for temp. sensor malfunction.
Do you still get that code?
Coolant coming out of both the overflow and the cap.
Caused by overheated expanding coolant?
Bad head gasket,rare on these cars.
Air trapped in the system.
bad thermostat.
bad water pump.
Starting to sound like you have an issue with the water pump not working.
