Thread: Car Overheating
Old 05-21-2021, 03:49 AM   #1
xX2pro4uXx20
In your other thread you said you were loosing coolant.
Did you find out why you were loosing coolant???
You say your coolant gelled can you see gelled coolant????
Are you sure your coolant gelled or is it possible that your still loosing coolant?
Heater not working???
I am just guessing here but perhaps the heater core is leaking.
Check for moisture under the carpet on the passenger side.
I think the heater core is on the passenger side behind the dash.
Hopefully someone who knows for sure will confirm.
Yeah it looks like before I was loosing coolant out of the cap since it was coming from the overflow tube. So my guess is the cap wasn't sealing. I can not see any gel anywhere, I'm just guessing in that one since it only started happening whenever I added coolant to it.
xX2pro4uXx20 is offline   Reply With Quote
