Old 05-20-2021, 07:07 AM   #1
JayG
On the slippery slope
JayG's Avatar
If you're only doing rears, you should try to match up with what's on the front. You defn don't want to put ceramic on the rears and have std material fronts. Different characteristics between the two materials and will give quite different results in the cold, heat, and rain. If you want to go ceramic, either wait until you can do all four corners or do all 4 corners now.
Both front and rear Powerstop pads together probably cost less that a single axel of factory pads
2004 996 Targa Tip
Instructor - San Diego region
