Old 05-20-2021, 07:36 AM   #22
Stl-986
Also, check for oil leaks around the spark plug tubes on the cam cover. This is typical of dry/cracked spark plug tubes. Ok to replace, cheap but just time consuming. These can cause misfires also.
for coils unless the crack is very obvious it will be hard to see them usually. cracked coils typicall cause misfires when driving in rain or getting them wet.
If you dont know when either were last replaced, it may be best to just replace all the plugs & coils, it isn't expensive.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
