Old 05-18-2021, 07:04 PM   #480
ike84
Originally Posted by Newsguy View Post
Though this thread is few months old, it seems the best spot for my question.
I've fitted the 997 'T" and 74mm TB. For clearance reasons, can I mount the TB with the actuator block on top rather than the side? There is enough cable to rotate 90 degrees but will it work fine in that configuration? I don't see any obvious reason it would care, but one of you might have contrary information.
Thanks!
Yes, u can mount the TB in any position you want so long as the connector reaches to accommodate fitment. I have mine (82mm on modified 996 cable driven plenum) mounted with the actuator on the driver's side. I'm not sure if Ben was replying to your post but it makes contact with the engine cover but it has not caused me any problems after driving like that for several hundred miles. I don't think you will have this issue though since the 74 is smaller. You can see the pic in my diy thread.
Sent from my POCOPHONE F1 using Tapatalk
