Old 05-17-2021, 02:19 PM   #10
Radman
Originally Posted by ike84 View Post
I use a magnetic mount that suctions to my windshield. I ran it flush along the dash so it and the suction cup are out of my field of vision when I'm driving.
I used a CD mount wedged between the upper and lower portions of middle console but it wasn't very secured. I also mounted one directly to the lower center console trim by drilling a hole there but it didn't last for more than a few months before it broke.
The only other option would be to mount a stand on the passenger side base of the middle console and run with stand over toward the center. This is how oem phones were mounted. It's not in your direct field of vision though so that may make navigation difficult.
Sent from my POCOPHONE F1 using Tapatalk
Similar to mine but mine plugs into the 120v port in the dash. That's when I found out not all accessory ports are the same size. I have it working while I procrastinate buying the updated assembly with the correct port size.
Radman is offline   Reply With Quote
