Old 05-17-2021, 08:37 AM   #1
Gilles
drive behind your wife and look at the tail pipes, if they move up or down when applying power (or releasing it) it is the front engine mount.. It is fairly easy to replace and you will find a step by step procedures on this forum.
I have a new insert left over from my 987 if you need it (Lemfolder..?) , but you will need to remove your front mount and take it to a tire shop (or a friend with a press) to remove the old insert and install the new one.
Good luck
