Old 05-16-2021, 04:57 PM   #11
Muskoka Minute
Muskoka Minute's Avatar
Originally Posted by bcrdukes View Post
Hi Bart,
The H&R Springs I'm running are a 1" drop as per their specifications. I've seen a few Boxsters in the city that are likely 2"+ dropped and scrape when going over speed bumps to getting in to shopping plazas. Even with a 1" drop, certain speed bumps will result in a scrape of the underbody. Wasn't worth the heartache in my personal opinion.
I ended up going to Brett Hunter at Hunter Motorsports for the final alignment because he was available next day to slot me on to his schedule. Our mutual friend was 3+ weeks out and I didn't want to wait.
I'll post my specs and his notes, where the values are as follows:
Front Left / Front Right
Camber: -1.81 / -1.85
Toe: 0.02 / 0.01
Rear Left / Front Right
Camber: -2.50 / -2.50
Toe: 0.13 / 0.14
Notes on the alignment left by Brett: 986/987 call for more negative camber in the rear than the front. This alignment reflects that.
Due to limitations of factory adjustment, the rear is as close as possible to factory settings. The car cannot have less negative camber, and toe can not be closer to perfect (0.09.) Toe front and rear is within spec.
Previously, I was running some specs that some of the guys here on the forum known for tracking their cars heavily and it was too much for the street in my opinion. -2.5 camber in front and -1.9 in back, zero toe front and .016 degree total toe in rear. Unless this was a dedicated track car running high speeds, I would never do this on the street again.
As for the Ohlins, ultimately it was the price, and if I was going to commit to the Ohlins, I wanted the full meal deal, which meant a lot of expensive parts and labour, it was going to be a point of diminishing returns.
There are days where I wish I had the Ohlins, but I still am very happy with my Koni FSD setup. I just got a software tune on it and it's scary fast now.
Thanks much for that.
So is your car still lowered the 1" or did you raise it back up?
When did you decide to go with the tune? did our friend do it or did you do it yourself ?
Appreciate your help..
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
