Old 05-16-2021, 02:38 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
I always remove the headlight switch when I replace it and look in from the place the vent sits. It's not that much time or effort if you follow this:
https://www.pelicanparts.com/techarticles/Boxster_Tech/87-ELEC-Headlamp_Switch/87-ELEC-Headlamp_Switch.htm
Don't forget the screw marked by the yellow arrow:
They ignition switch (electrical portion) is the first step of this:
https://www.pelicanparts.com/techarticles/Boxster_Tech/86-ELEC-Ignition_Switch/86-ELEC-Ignition_Switch.htm
I like to use a screwdriver set like this to easily get the screws out and back in:
