Old 05-16-2021, 11:51 AM   #4
blue62
Originally Posted by DKGray View Post
Is anyone able to tell me if there might be a root cause for all of these:
DME fault codes?
P0139 02sensor ageing behind cat c, bank 1
P1128 Oxygen sensing adaptation, idele range, bank 1
P1130 Oxygen sensing adaptation ideal range, bank 2
P1126 Oxygen sensing adaption, lower load range, bank 1
P1133 Oxygen sensing adaption, lower load range, bank 2
P1117 Refer to service manual
P1119 Refer to service manual
P0446 Shutoff valve, activated charcoal filter (function)
HBA Control system
1 Engine path left
2 Engine path right
I misread this post the first time I looked at it.
The P0139 code is for an aging sensor behind the Cat on bank 1.
Nothing you can do to fix that except replace the sensor.
All the other codes are for Pre Cat O2 sensors on both banks.
Some are rich threshold limit codes and some are lean threshold limit codes.
I need more information on the car to be of any help
like
Year?
Miles.?
Is it all stock??? or are there modifications???
Any recent work done to it?
