Old 05-15-2021, 05:17 AM   #15
PLP
PLP's Avatar
I am not sure if it is better to start a new thread or steal one...
But then - it is very same topic, although slightly different issue.
I went through the learning process and the windows switches operate correctly. I suppose.
One short tap - it goes automatically up or down. Push and hold - will roll until released. Is that right?
Now, the drop.
Drivers side.
When I grab the handle from outside - the window drops enough to clear the roof. However, I must HOLD the handle in pulled up position when opening the door and do it slowly for the window to stay lowered. If I do it too quickly - it will go up.
When closing it (and I managed to open it slowly and the windows is dropped), the window will close.
If I do it too quickly, it will drop only to go up right away. When closing in this situation, I must pull the handle (window drops) and while keeping it pulled, close the door.
From inside - surprisingly it works. I pulled the latch and it glass drops, close from outside - will go up.
Passenger side - does not work at all.
But both sides will drop when opening or closing the roof.
So, what am I looking at here?
PLP is online now   Reply With Quote
