Old 05-13-2021, 09:50 AM   #5
Stl-986
use the durametric for the misfire, torque wont show those. It will show pending codes though as well as codes that are set.
Pictures of exhaust help, but that sounds about normal. It's tight in there.
if the clutch switch is bypassed it wont impact cruise, other then not disengaging it if you use the clutch. Not ideal but easy & cheap fix to replace if it is actually bad. Takes about 5 minutes.
Shifter is known to get play in it. There are several writeups on this and youtube videos.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
