Old 05-13-2021, 06:59 AM   #20
blue62
Originally Posted by bg305 View Post
This is a good idea, I am going to give it a try if I can locate a helper.. would be nice to see if it is bank 1 or 2. Bank 2 has the big deviation, but it sounds like it is coming from bank 1.
Also,
Do you know if I would expect these numbers to be off more if pads had been compromised / deteriorated badly or is just telling me that the actuators themselves are doing their jobs cleanly?
The 25 degrees is how much the cams advance when the Variocam actuator kicks in.
If your starting out with 9 degrees of negative Cam deviation due to the pads being compromised or worn. Then when your Varocam system kicks in your really only getting 16 degrees of advance on the Cams because you are starting out 9 degrees retarded.
I hope that makes sense.
The actuators seem like they are working fine. The issue is you are starting with the 9 degrees of late cam timing=deviation.
