Old 05-12-2021, 01:40 PM   #1
bg305
01 Seal Gray 986 S
bg305's Avatar
Engine noise diagnose assistance - Possible vario cam actuator/pad/chain issue?
First of all thank you to everyone taking the time to read and reply, I appreciate your thoughts.
Background: 2001 S, 53k miles, Fabspeed exhaust, tune (I believe done by fabspeed, it happened 2 owners ago). The tune is possibly ROW, but I do not know for sure. The reason this believed is because it does not have the normal amount of emissions monitors. I have owned it for a bit more than a year and 1/2 and replaced the AOS when i got it. So far as I know no other major work has been done (original IMS assumed, no chain guide replacements, etc). I noticed a small amount of brown plastic in the filter last oil change from the vario cam pads. It was my second oil change since owning the car and the first I did not see any plastic, but I do not know how long the oil was in it that time. Other then that the car was running like a champ.
I have been monitoring my camshaft deviations since I found the plastic (this past fall) and they seem to sit around:
Camshaft 1: -0.74 (this does increase to 1.60 or a bit more as it warms up and then goes back down)
Camshaft 2: -9.27
Now the problem / question:
I was out for a nice drive a couple of weeks ago, enjoying a corner probably in the 4-5k rpm range in 2nd, some g-forces but nothing crazy, let's call it 60% of what the car could do in that corner. I noticed mid corner the engine seem to take on a different sound. The intoxicating whale sounded more like a Subaru (Not picking on flat 4's, that is just the best way I can think to describe it).
I drove it home 8-9 miles cautiously. It is possible it had lost some power, but given how gingerly/cautiously I was driving it, it is more likely just my perception. If there was a change it was not big.
I finally got out today (work has been insane for a bit), put it in service mode and checked the intake for obvious leaks and the exhaust (just a quick check, nothing detailed, the car is still on the ground). So while I can't discount a leak in the intake / exhaust, I do not see any evidence to point me in that direction.
My concern of course is the vario cam actuator / guides and chain. I am far from an expert on these systems but am hoping that this video I took will help show the data in a way that someone here might see something if there is an issue
I had planned to try to get through the season and then replace the vario cam pads along with a pro-active ims / clutch /etc. But I think i might have to do that a bit sooner possibly.
Note: at the beginning of the video I say crank angle, but meant to say cam...
Hopefully this drive link works:
https://photos.app.goo.gl/eJM9qYHyqL1TrkUg8
Thoughts? Do you the noise is related to the vario cam system? It seems to start right @ 2500 rpm when the angle changes. (Although it seems to disappear a bit or become harder do separate from the normal engine sound as I went up the rev range). Do the actual cam angles appear normal in the sense of where they start, when they change, etc ?
bg305 is offline   Reply With Quote
