Originally Posted by Stl-986
If the top needs to be replaced and you are going to have a shop do it, budget $2k. When it's off they should lube the track, which is most likely causing that "jaggedy" but it could be that it just needs to be adjusted.
Thanks, this is what I figured. I'll make sure to get a quote during the PPI
