Thread: New Member
Old 05-12-2021, 06:45 AM   #1
CD986
Does the engine crank = turn over?
Headlights come on?
gauges work?
Any moisture under the carpets on drivers side?
We need more info to be able to help.
You can use search mode on the upper part of your screen.
It was stored in a garage. Initially, the battery was dead but still fairly new and under warranty. I took it to Interstate Dealer and they recharged. Then tried to start and it cranks, lights come on, stereo and gauges work but it will not start. Also, prior to storage, the car was running quite well. No other problems. This led me to believe that there is some sort of lock out or security measure that needs to be reset.
CD986 is offline   Reply With Quote
