Originally Posted by Boxstard
I thought the tube ID at MAF is 74mm so it’s the bottleneck if you use a bigger TB.
You are correct. I completely forgot about it until you mentioned it but I also went up to a larger maf housing size, 3.25 or 3.5 inches (Don't remember off the top of my head but I think it was the TB for a 4.4l bmw v8) when I redid my intake. In retrospect, the dme's problem was probably moreso that than the 82mm TB.
Sent from my POCOPHONE F1 using Tapatalk
