Old 05-09-2021, 11:49 AM   #10
JFP in PA
Originally Posted by ike84 View Post
That's interesting. One thing I have read about IMS bearing failure is that some shafts (and hence the bearing) seem to be off centered and that this eccentricity leads to bearing failure. Do you think that removing the chain tensioners before IMSB install and then reinstalling at the end eliminates this problem?
Sent from my POCOPHONE F1 using Tapatalk
Absolutely not. Once everything is reassembled, off center shafts, or engine cases, will still force side loads on the bearing as the real problem has not been addressed.
Removal of the hydraulic tensioners is essential during an IMS retrofit because not removing them, as many have discovered the hard way, forces the shaft to one side and prevents removal of the bearing, and can also lead to one or more chain jumping time, which leads to no end of problems. We have had more than one totally failed retrofits flat bedded to the shop because the owner’s never bothered to read the instructions for doing a retrofit, and then ended up paying us thousands of completely unecessary dollars to put the car back together.
