Old 05-08-2021, 10:49 AM   #10
Cunningr
Cunningr's Avatar
Originally Posted by Zordrack View Post
Speaking of door subs.
How much room is there between the "sub" and the door panel ?
Wondering if I can fab an adapter to squeeze a 6.5" woofer into that 5 1/4" opening without it hitting the door panel.
Basically I was gonna cut out a half inch thick HPDE, bolt that into the OEM driver location and dremel it out till it would take a 6.5" shallow mount driver.
I used an adapter for a mitshibushi, i think was .5” to install 6.5” woofers in the doors. Did not have a clearance issue. I bought some second hand nokia door boxes for 986 to cut up and modify then bolted in used stock wiring harness.
