Originally Posted by Smallblock454
My box was in the workshop.
Got new DMF, clutch and IMS bearing.
Since than i have engine vibrations starting at around 2 to 2.5 rpm upwards. And they are getting worse.
Yesterday when cold starting the car i've got a rattle noise for 2 to 3 seconds. Sound like a timing chain was banging against the engine housing. At first sight to me that means a problem with the chain tensioners.
Is it possible that that damn workshop has interchanged the 3 chain tensioners (so they are not in there original position) and that is causing the engine to vibrate at higher rpms?
Thanks, Markus
You ask if the shop interchanged the tensioners, but replacing tensioners isn't on your list of work performed. [emoji848] I'm somewhat confused by that. Did they replace tensioners?
I'd focus on what they changed/ touched.
Why did you replace the dmf? What were you trying to solve? Was it replaced with an oem unit? Was it new or used?
Ike asks a very good question: clutch pedal in or out, any change?
