Originally Posted by Smallblock454
My box was in the workshop.
Got new DMF, clutch and IMS bearing.
Since than i have engine vibrations starting at around 2 to 2.5 rpm upwards. And they are getting worse.
Yesterday when cold starting the car i've got a rattle noise for 2 to 3 seconds. Sound like a timing chain was banging against the engine housing. At first sight to me that means a problem with the chain tensioners.
Is it possible that that damn workshop has interchanged the 3 chain tensioners (so they are not in there original position) and that is causing the engine to vibrate at higher rpms?
Thanks, Markus
What's a dmf?
The cams have to be locked down when the ims is replaced - if they didn't do this then the timing could be all off. I'm not sure if that would cause a vibration but it would definitely run rough (and you wouldn't have much power from the motor either)
Does the vibration happen with the clutch pressed in and revving the motor? If it doesn't, Could the clutch be off balance and that's causing the vibration?
Sent from my POCOPHONE F1 using Tapatalk
