Old 06-04-2004, 09:46 AM   #6
mrmickeymouse
Sometimes the little lever that activates the microswitch, becomes soft with use, you may be able to bend it up, and then it will oprate correctly.
Any good electronics store [except for Radioshack] will have a reasonable priced switch, that you can swap out, if bending the arm does not correct the problem.
Scott
mrmickeymouse is offline   Reply With Quote
