Thread: 986 no crank
Old 05-06-2021, 08:28 AM   #11
Stl-986
Let's start over. lol
You replaced the positive cable right? Did you disconnect the negative cable when doing this?
What I would do is 1st start checking your fuses. get a multimeter and check continuity on all of them. Do not rely on just visually checking. If all test good, next test the fuse at the immobilizer. Make a note of any that you replace.
Not sure what the nss is you refer to.
let's go in steps and not just throw out 50 different things that it could be, much easier that way.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
